How about being able to manually hide selected cells in a map.
Right click menu or hot key.
Just throwing this out there, any way to have the software scan for supported controllers when issuing a read (or write, that'd be even cooler) command and then read both the ECM and TCM out back to back? Maybe even have a dialog box pop up asking for save location and filename BEFORE the read so you are guaranteed a pair of untouched stock files. That would save some time and keep people from asking why they cant tune the trans. Of course keep the existing flash commands so if you have the trans setup perfectly and are tweaking the engine you dont have to flash both, just wondering if this could be added easily (or at all).
But if not I can dream right? :)
Can Milli-volts (mV) be added to the NBO2 PIDS? (imperial/metric)
I know it can be done with a calc.pid making it somewhat frivolous,
but why not.
You can add a custom unit for the HO2Sxx PIDs so that when you press Enter on FlashScan's keypad it changes between V and mV.
To make mV one of the preset custom options for all PIDs with V units, you can add mV to the file:
\ProgramData\EFILive\V8\EFILive.ini (Vista)
or
\Documents And Settings\All Users\Application Data\EFILive\V8\EFILive.ini (2K/XP)
by adding an entry in the [Unit Conversions] section like this:
0110=V mV 0 1000 0.000000 N
Be aware that file (EFILive.ini) may get overwritten during a future update. Currently it is set to not be overwritten but that may change in future.
While you can't select the data file folder name during the install, you can change it once the software is installed.
Use the Scan Tool menu: Edit->Properties->Folders and highlight the "Logged Data" item. Then click the [Browse] button to select a different folder.
You can also double-click on some items ("Logged Data" item included) to toggle the "remember last folder option".
Log filenames based on tune filenames...
e.g.
if tune filename is 12212156_0007.tun, then successive log filenames will automatically be:
12212156_0007_0000.efi
12212156_0007_0001.efi
12212156_0007_0002.efi
12212156_0007_0003.efi
12212156_0007_0004.efi
I use SyncToy v2.0 and an external HD to keep things sync'd and for back up.
When I adjust or make a new file I'll Bluetooth the files between my 2 laptops or copy from the EHD, I'm too cheap to buy a USB transfer cable.
:offtopic:
What about my idea in post #1?
