Yes, we expect to have at least the same number of PIDs available for BB logging as we currently have for pass through logging.Quote:
?Quote:
Originally Posted by Gelf VXR
Can you do LC-1 firmware update through the V2 cable ?
Cool... thanks... :cheers:Quote:
Originally Posted by Blacky
I'm not too keen to do firmware updates on my LC-1... I tried this once one time and my LC-1 stopped working (Innovate did fix it up for me).Quote:
Originally Posted by tunedbyGM
This and an ethernet cable would do the trick also!
http://www.rogerssystems.com/store/m...Product_ID=430
I think it comes with 8 pins on wires ready to plug into the DB9 connector.
Ira
No.Quote:
Ira,Quote:
Originally Posted by Ira
I think Paul has found one already, see the last link in this post: showpost.php?p=64483&postcount=37
It's low profile and it's under $3.00. :cheers:
Thanks , only reason I asked the V2 video has to be the latest firmware 1.10v because the LC-1 goes to 99% on heater warm up percentage .Quote:
The LC-1 used in the video has the latest firmware, but that was done using Innovate software. There is no way to do it from EFILive, nor would we want to try. Regards PaulQuote:
I understand , stay out of the chain of faults , if firmware flash goes bad then it is Innovates thing .Quote:
So best not to ruin the LC-1 com then !
