Correct. Can you add something in the Advanced Options to allow S10Mods to flash a 1024k file into his 512k RR? Maybe an OverRide?
check out post 70, http://forum.efilive.com/showpost.ph...6&postcount=70
Craig said the RR units will accept up to a 1mb file and that they dont care what pcm they are installed in to. what he is refering to not working is if you upload a file in to it that is not a match to the pcm the RR is installed in, that is what wont work. like if I didnt remove the emulator from my LS1 pcm and tried to run the ls1 pcm in my v6, that wont work. but since I put the RR in a v6 pcm and flashed the v6 file, it now works. what we are wondering is can EFILive give the permition to flash a 1mb file in to our purchased as 512K RR and vice versa? for this to work correctly it is assumed that the RR will be installed in to the proper pcm for which the file is intended for.
The LLY, E40 use a different flash chip than the LS1, LB7 etc, Craig might not have designed it to handle emulation of a burst flash device even though they are 1Mb.
The E38 & LBZ ECM's are even worse, burst flash but also 32 bit, plus running at 50MHz or so, not low 20MHz rates like the LB7.
I'll ask Paul to look at this thread, he will need to confirm why the restriction is in there.
I built in a check to make sure the correct file was going into the correct RR device. We have to cater for everyone's skill level- if you know what I mean.
That said, I figured someone would want to bypass that check. So to bypass it, just hold down the Ctrl and Shift keys while clicking on the RR full flash icon.
But if you do that, then we are not responsible for the aftermath if/when the RR PCM fails to operate the target vehicle correctly.
Thank you, I cant wait to try it out, I know the RR makes tuning so much faster, I am so glad that it works in my grand prix. I just finished tuning the trans parameters, it didnt taks much time at all to get it right where i like it.:grin:
Yeah, we should finish off support for those V6's one day :music_whistling_1:
Funny... honda people and Crome use a pretty darn long cable.
Ross.. I am missing something.. .v6 3.8s?
GM 3800 support would be great. maybe some day it will be avail.
