This is precisely why I need support for my T76 please please please. I have a passenger in my race car that says "slow down, slow down" (TCM)
Bummer. I'll just have to hope time flies until then. I really need it and can't wait. But thanks for the update and I'll be hoping for the best!
Hi I am looking for someone who knows what the table needs to look like to work right with 6L90 and e 38 controller.
Trial and error I'm afraid, log the torque PID from the ECM to make sure your changes are going in the right direction. Re-read this thread (I know it's very long) but there is a lot of discussions in this thread from people trying to tweak the torque tables.
If you are still a little lost then maybe give a some more details on the engine combo, what has been done, how is the trans behaving.
its gm 6 liter and 6L90 transmission
when going uphill when you press the gas the vehicle is running like reving but the transmission is not shifting until you release the foot off the pedal
I don't know if this would cause any transmission to burn the clutches or stuff like that
If the trans is slipping then there is an internal hydraulic/mechanical problem.
Otherwise the shift tables must obey relative relationships (if they don't then they may be inhibiting particular shifts)...
for example, the 3->4 upshift table must be above the 4->3 downshift table (by at least a few MPH), and must also obey the engine RPM limit.
Not shifting due to hitting the engine RPM limit should not cause trans problems, but may sometimes cause engine valvetrain problems (depending on situation).
:bash::throw:
