I am currently using COS 01250003. Can I use the 1290005 OS? My GM Stock OS was 12202088 (2001).Quote:
Originally Posted by Flyer
I sure would like to try this OS.
Thanks.
Bill
:master: :beer: :notacrook:
Thanks.
Bill
Don't think so. The 2002 Camaro was 12212156 from memory. The Custom Os stream 0129000x matches stock OS 12225074, which I believe was only used in Holden Commodores.
That is what I was afraid of. Any idea when/if they will support the 12202088 OS?Quote:
Originally Posted by Tordne
Bill
Check if you can update to the Camaro 02 OS 12212156, I think that is the other OS that Custom OS V5 is done for ;)
Behold the power of search. Too bad I messed my skivies before I found this post.Quote:
Originally Posted by GMPX
Why do you need OS5 support for that OS?Quote:
Originally Posted by BowlingSS
Bill, you can probably upgrade to 12212156 and then go to the 02020005 V5 OS.
YOU CAN USE COS5... you JUST have to manually copy and paste all your calibration data INTO that OS.. that is all! :)Quote:
BTW.. copy entire segment doesn't work.... is this still supposed to work? its greyed out.
Copy entire segment does work, did it the other day :) Not between different OS's though obviously.
open a tune and an alternate like you are doing a comparison. Then it is available.
Ah.... actually
with all the table numbering being exactly hte same for all OS, it should be available... That is all left as an editor.
