Switched to 14.07 stioch, only one problem, My motor likes to idle at 13.97 AFR
Hey all,
I have switched to lambda so I could learn more about tuning in general.
I seems a little backwards. So I have a problem that is a little different.
Mt car does not like to idle at stoich (14.047 for my stoich now), never did. My motor likes to Idle 13.97 AFR. It is not the fuel this time either as the motor is much happier now over all adjusting the needed AFR tables. But how do I convert the open loop to Lambda with this AFR up to operating temp and then to idle. It is not stoich but the motor likes it, This is not uncommon I am told for a built motor. So how do you convert AFR to LAMBDA accurately here. PE is now fine. I do not have my PC in front of me so I am sorry if I have said something wrong but I think you get the idea. Any ideas?
98 tigershark
Thanks SSpdDmon and gmh308
Yes that does answer the question very well and it is appreciated very much.
Thanks again, I owe you guys.
98 tigershark
