Ha my CS classes wanted us to use Crimson Editor, hasnt been updated in 5+ years now and the project is dead. Switched to Notepad++ 2 years ago, really like its versatility.
Allow the engine oil pressure calc pid to show up for Camaro/Firebird (so we don't have to artificially enter a Corvette VIN).
Scantool chart data highlighting/selection -> Tunetool table cells highlighting
currrently this has a limit of 100 frames
can this be made a user option (to select how many frames) (the user is responsible for any slowdown resulting from setting this to greater than 100);
can there be other options, such as highlight the table cells where the local maximum/minimum occur in the highlighted/selected chart portion (rather than highlighting cells from just the first 100 frames);
other options regarding this that I have not yet thought about... :doh2: i.e. that you may have.
Can we add the tool bar options to the conversions tab?
Linear Fill, Smoothing or user defined custom labels.
Can we see about adding B9021 minimum transient p/w.......(Minimum injector pulsewidth during transient conditions
This table has been shown to limit the minimum pulsewidth in some operating systems.) or it's equivalent parameter to the 1mb PCMs???? My OS is 12587603 and i would like to have this option. Or could it be added to the corresponding COS3????
Corey
After doing some black box logging and opening the log in the scan tool, I would like to be able to open a pid file to add calculated pids to my log (Like for calc.ve). It won't let me do this after there is data in the log file.
You can add calc_pids to a log provided the prerequisite pid(s) were logged.
They can also be set to open automatically in the V8 software w/BBL.
Like mr.prick said, you can add calc pids after a log was taken (if it contains the prereq. pids), and you can save them into the log.
Yeah, it's just annoying to have to add like 8 of them, especially since some of them depend on previous calculated pids. I can save the pid file, but can't open the pid file when there's already data in the log.
