Have you alerted Blacky to this problem... a little hard to cut and paste and multiply hehe....
I am aware of the right-click-menu problem. It was reported by Delco earlier this week. I have corrected the problem. I'll upload the corrected version and post a link to it. Mr Prick, I've also updated GM.MANVAC and a couple of other inHg PIDs.
http://forum.efilive.com/showthread.php?t=8810
No one knows?
I've got the latest software, but at Carlisle this week, I noticed that I could not Right click/copy and I was still having some connectivity issues......
Serial wideband works nice with LM2.:cucumber: (thanks Andy!)
Otherwise, working pretty good....
Chuck CoW
I haven't posted the update yet - still waiting other issues to be fixed.
You can still use the Edit-> menu at the top of the window to copy and copy with labels.
Ok where is the options.ini at , is it hidden ? Not in the "confg" folder .
Unfortunately, it (and other files) will move again in the next release.
EFILive V8's design, which was made before Vista was released, called for the entire software application, data and config files to be stored in a single folder. Which meant it would be easy to backup or even transfer your entire setup to another PC.
It seems Windows Vista security model does not like applications "saving/updating" files in the Program Files folder. So rather than fight Vista's security model which will cause grief for many customers we are currently investigating moving the application data files to:
On Vista it will probably be:
C:\Users\<username>\AppData\Local\EFILive\V8\...
On Windows XP it will most likely be:
C:\Documents and Settings\<username>\Local Settings\Application Data\EFILive\V8\...
Also EFILive V8 does not store config data in the registry. All config data will be stored in *.ini files that can be easily backed up or transfered to a different PC along with the other application data files.
Gotta love Vista ......
