This will get you what you want until then. :blahblah:
Hi Rich,
Most of us manually move the chart inspector/cursor back/forth thru the chart when analyzing a log...
if you wanted to to play segments of the log, then you could crop each segment and save to a new file (one segment at a time), this would then let you integrate with your video(s).
Yes, I have been doing that as well, but when scanning through a LONG log file just looking for anything that looks *different*, it's quite tedious that way. Maybe when I am more familiar with this stuff I won't feel like I need to look at EVERYTHING, or will know exactly where I need to look for something. But right now, I just don't know what is "normal" and what is not. So I am presuming the longer I look at log files, eventually SOME of the stuff will have to be considered as normal, and the stuff that is not normal will become more apparent to me.
Ooh, I've got another one....
I'm looking at a log file, and want to look at ONLY the relationship between two of the values being tracked. Sure would be nice to have a way to QUICKLY hide the tracks I don't want to see at the moment. Something like right clicking on the trace or the label and just being able to select "hide" and then being able to make it visible again as needed. Kind of like when looking at multiple parallel audio clips you can mute any track separately.
Just a thought....
Sure would be simple that way. Right click and have a list of all PIDS in log then click the ones you want to see! Simple! That is the way TunerPro RT is set up...
Is it safe to start learning the V8 Scan Tool? I've never touched it.
My understanding is V8 is going to replace all V7.5 stuff?
Suport for Dodge gas engines,
any chance of this happening?
:angel_innocent: :w00t: :coool: :drool: :Eyecrazy: :D:cucumber: :hihi: :cheers: :grin: :rockon:
