You need to have the appropriate files in the [Config] folder. Use EFILive_Explorer to manually setup the files or use EFILive_ScanAndTune->Black Box Logging to setup the files.
Then you need to select the correct controller type using the F1 option on FlashScan.
Then you can select the switchable tune.
