So I've been a busy boy today and added a bunch more stock tunes. In fact 33 new ones :Eyecrazy:
Check it out!
Check it out!
FWIW, all 02-03 TBs have the I6 and only the long models from 04-05 got them in the TB, the Voy got the 5.3L V8 in the Denali model in 05 but the TB has the LS2 6.0L V8 in the SS model. Thats power baby!!:muahaha: :rockon:Quote:
Originally Posted by Tordne
(BTW, all TB platforms are autos, there isnt a manual trans option which for me isnt a big deal however it is for some.)
And, I will send them over soon.
Any idea where I can find tune file for a force induction low boost turbo .??
I have a corvette C5 win STS turbo kit .
any idea please ?
There are a couple of radix tunes but not for corvettes. Take a look at them to get ideas. You will almost never find a tune which matches 100% even if you did Id definately not run it. You dont know what state of tune its in. Might be stage 1 of a 50 stage tuning process.
Bottom line, is read and look at loads of stuff to get the basics sorted and once you have the understanding make the changes in your tune.
thanks for your helpQuote:
Originally Posted by ringram
You're right . I'm not asking for 100% tune. I only need the guidelines and then I can start from there .
You did not mention where I can find the tunes at ?:master:
thanks for your help again
The link in my sig - I host the repository ;)
YES I KNOW ... BUT I could not find anything for boosted engines :nixweiss:
waiting for your help :wave:
In the modified tunes section there are a couple that list radix. They are supercharged tunes aparently.
Quote:
2001Camaro Coupe 5.7 Litre Manual LS1 12202088 483,125 Bytes F13 Cam (230/232 .595.585 112), Stock Heads, Ported TB, QTP Headers, LS6 Intake, Lid, SSRA, True Duals, 3.42 Gears
i dl'd this modified tune because i want to install an F13 in my 02. the mods are pretty much identical to the one listed minus the td's and ssra. whenever i happen to do the swap, i can just upload this tune to the pcm and be good to go right?
Tread with care young one. No guarantee the tune is good or a perfect match. You are better to use it as a reference rather than as a base.
If you are the gambling type throw it in. But you best be on your toes with logging and make sure its not going to throw you lean and/or detonate your pistons to pieces etc.
How do you know they arnt running different injectors? Or MAF etc?
