in scantool: use the CALC.VET that has units g*K/kPa.
in tunetool: go Edit->Properties and set VE units to g*K/kPa (only has to be done one time).
I updated my V7.5, V8, bootblock, & V2 firmware.
I'm not able to see any GM pids, in the scanner pid list. I have the SAE, the CALC, and the EXT pids, but not one GM pid. (They were there B4 the update.)
"Validate pids" runs, but doesn't change anything.
What am I doing wrong?
Scan/Tune: 7.5.7 build 170
BootBlk: 2.7.2
Firmware: 2.7.14
Make sure all the 'Unsupported Pids' are checked.
Post up a screenshot of your problem and your calc_pids.txt file.
Thanks..
http://tinypic.com/r/9hq90w/7 http://tinypic.com/r/9hq90w/7
http://tinypic.com/r/ezn1vk/7 http://tinypic.com/r/ezn1vk/7
The calc_pids.txt file is basically WmanShawn's file w/ one change, (displacement).
I believe you are referring to the "supported" check box. It is unchecked (show all).
You do not have the GM.DYNAIRTMP Pid selected. If you right-click on any of the red-X Pids, it will tell you what other Pids you need selected.
What is your OS? Have you Validated the Pids per these instructions?:
I. Validate Pids:
1. Connect Scan Tool to your Vehicle (Select Controller)
2. Turn Ignition Key to 'On'
3. Scan Tool>>Info>>Validate Pids
If you have done all that, then I am assuming your OS may not support all the Pids. That is a little over my head, so post up the information requested and we will go from there.
I replaced the calc_pids.txt file w/ an empty file. There was no change. (The X-out calc pids are not in the list. Still no GM pids.)
None of the PID lists have GM pids in them. i.e. Default LS2 Metric.pid
Notice the PID count @ the bottom of the PID screen, only 44. A very small number.
I did the validate pids routine. There was no change.
OS=12212156
All the pids in "your" calc.vet list are supported. I have a scan I took B4 the SW update.
Thanks for trying,..
Isn't your Controller LS1B?
GM.DYNAIRTMP.DMA is found under the 'Tune' tab. Why are you using the Default LS2 Metric pid list?
Also, see Paul's post here: http://forum.efilive.com/showthread....l=1#post149621
Yes, it is an LS1B controller.
I mentioned the fact that there are no GM pids showing in the Default LS2 Metric lid list as well.
i.e. My scanner is not "seeing" any GM pids, regardless of the PID list selected.
I don't have the GM.DYNAIRTMP pid selected, because there are no GM pids to select.
This is the PID list that I am opening inside of the scanner: (WmanShawn_CALC.VET.pid)
[Parameters]
CALC.LTFTBEN=1,4307
CALC.PE=1,4308
CALC.SELBEN=1,4315
CALC.VEN=1,4317
CALC.VET=1,4320
CALC.WO2BEN=1,4321
EXT.WO2LAM1=1,4396
GM.CYLAIR_DMA=1,4481
GM.DYNAIRTMP_DMA=1,4503
GM.ENGSIZE_DMA=1,4524
GM.EQIVRATIO=1,4531
GM.HO2S11=1,4634
GM.HO2S21=1,4632
GM.MAFFREQ=1,4735
SAE.ECT=1,5126
SAE.FUELSYS=1,5136
SAE.IAT=1,5134
SAE.LONGFT1=1,5142
SAE.LONGFT2=1,5143
SAE.MAF=1,5144
SAE.MAP=1,5145
SAE.RPM=1,5165
SAE.TP=1,5172
