Did you address the rod ratio issue, or just put stronger rods in, in hopes they don't fail?
The motor is using a 5.9 crank, Carrillo rods, as wells as several other internal mods to make durability and rigidity issues minimal
Unfortunately I have been sidetracked on the RPM chase, but from what I recall when testing some OS's didn't play nice and still have hard RPM cuts at 3900 RPM (or there abouts).
any ideas what operating systems were giving the trouble?
I thought that would be the next question :grin:, the answer is sorry I don't remember, I'll have to see if I still have on my work computer the files that Brayden was working with and I'll let you know what OS it was.
Thank you sir
11551035 was the one he was running.
Is that the one that gave trouble or worked thanks again
11551035 worked, doesn't mean others wouldn't either, just that it did.
Thanks once again
