The attached file has the manual high idle feature enabled and will work without messing with the TIPM. I should replace your 405 OS without any issues.
Ok thx very much.
I really appreciate the help. Just getting started with my V2 from Anarchy tuning myself. Have read almost every thread on here.
So how would I go about pasting my tune onto this file? And I assume just enter my VIN into it to make sure it matches and I should be able to flash the truck?
Yes, you will need to be sure that your VIN is correct as well as the anti-theft settings.
You can copy and paste your tables over, or create a script of your current tune and run that over the new OS.
Ok I opened up the high idle file and I noticed it does say manual for transmission and mine is an automatic. So this probably won't work then...
Auto file attached: Attachment 19100
So I couldn't figure out the scripting yet so I just copied the tables over, put in my vin, and flashed the truck and it works!
Glad to hear that it worked for you!
Awesome! I've been looking for this for a while! Works Great!
I decided to try the auto high idle file as well. Converted to csp5 and ran a script. Worked perfect! Thank you!
