Ok I just looked at Freemans tune and it is in Lambda. So if it has a value of .9 and I want to richen it up I would make it .8?. Just when I thought I knew what to try:confused:
Yes, by changing the value from .9 to .8 you will be adding fuel. Like I said before though, try changing the units displayed and use whatever works for you.;)
Yes, if it's in lambda, then 0.8 is richer than 0.9;Quote:
Originally Posted by TLKSCHP
(the little voice in back of head was telling me something about bad assumptions... ;))
As Doc said, in your tune tool, go Edit->Properties and change the "Commanded Fuel Values->Display In" to either AFR or EQ;
lambda will twist your mind unless you're a mental giant. :D
What is the default setting for EFILive? AFR?
I think the EFILive default is EQ, and the PCM uses EQ.Quote:
Originally Posted by black z
