Also wondering if alternator control has been added?
Bump?
Having issues with my check charging system message coming on every now and then; esp at startup
Its not in EFI, but HPT has the tables.
Attachment 20581Alternator control no BCM is there a way to fix this tune
Just wanted to bump the thread. Has this patch been added to EFI Live or are we stuck still going to the "Other" tuner? I've been dealing with the 13.6V, but now I require more power for all the accessories I am adding.
There is always the option to use one of these, I use one on my Gen V swap and works perfect outputting 14.5V or so.
https://www.amazon.ca/Generator-DROK...7KVYQ78K&psc=1
what OS. someone might have time to provide the info for a cax file. I've been delving into the ecu/tcm code myself lately so could potentially help.
Attached is my tune.
Attachment 24467
Save this to a text file and save with a .cax extension & place it in the C:\Program Files (x86)\EFILive\V7.5\Calibrations folder if using v7.5 with your os number for file name.
[G1000]
; Description
DESC.001 = Alternator Voltage Control: Indicates the vehicle is fitted with a regulated voltage control alternator and serial message duty cycle control from BCM is available, if disabled DC will be 100% when alternator is enabled.
; Seg Caption Major Minor Vis Dis 2D Grp
VIEW = 7 "Voltage Control" "Alternator" "" 1 1 0 0
; Address(es) BitOff Bits Typ Inv
ADDR = 1C0F04 0 8 SED 0
; Units Factor Offset Prec MinLimit MaxLimit MinUser MaxUser
SI_SLOT = Units 1.0 0 0 0 256 0 256
; Body Col Row
ULABELS = . . .
; Enumerations
SI_ENUM = "0=Not-Fitted,1=Fitted"
; Units Labels
SI_COL = .
IM_COL = .
SI_ROW = .
IM_COL = .
[G1001]
; Description
DESC.001 = Should only be enabled if Voltage Control is enabled. Indicates that the ECM can override the serial message alternator duty cycle to boost system voltage when required.
VIEW = 7 "ECM Override" "Alternator" "" 1 1 0 0
ADDR = 1E4720 0 8 SED 0
; Body Col Row
ULABELS = . . .
; Enumerations
SI_ENUM = "0=Disabled,1=Enabled"
IM_ENUM = "0=Disabled,1=Enabled"
; Units Labels
SI_COL = .
IM_COL = .
SI_ROW = .
IM_COL = .
