i will give it a go
what is the best setting for play back mine was set at 3,000 and i all ways get the message 3,000 frames re plot ?
if i up it max will that do any thing detrimental to the play back
You can set that value to whatever you like really. I used to have mine at 30,000 but have dropped it back to 3,000 so I get prompted more. Sometimes I don't want to plot straight away and in V7 it does take a while. In the V8 Scan Tool those operations are going to be significantly faster :)
I've always found that with the E38 / CAN bus, that "stream-fast" caused problems with pass through logging. I did some testing very early on and found that "dynamic" give the best results. I know that in theory "stream-fast" should be the go, but I think it works better on the LS1 controller. Perhaps it's the 10 fps vs 40 fps (LS1 vs E38) that causes an issue. 10 fps on the LS1 is "fast" but is too slow for the E38 at 40 fps, I'm not sure, but I know that "dynamic" works much better than "stream-fast" for me
Simon.
i have tried both dynamic and stream fast no different
i noticed that on play back the big pc runs the charts about 2x as fast
now i have a problem when i tried to program some other pids in to the v2 (after upgrading the latest VER soft ware from the site) E38 list it says $0194 write failure whats happening ?
it say 85% 15% free on the little graph bars at the bottom of the pid list page i actually took some out
i had 28 now im trying to load 26
How full is your SD card...?
The chart at the bottom of the BBX setup screen only shows how much space (of the entire config file system) that the selected options will use.
It does not know anything about what files are already in the config file system.
If you have files on the config file system that are not being utilized by BBL, they are still taking up space but not being "counted" in that diagram.
The best thing to do if/when you get a $0194 error (which usually means file system full) is to format the Config file system using the drop down option on the [Program] button and then [Program] the files.
Ah, I just remembered that the [Config] space in on the internal flash... :doh2:
