It is an electronic throttle...how do i help that?
It is Electronic throttle how do I fix that?
You dont "fix" that man, just means there's no throttle cable just wires going from the pedal to the PCM to the throttle body. You should see something change with 0ing TM and PE delay.
Post your tune up man, we cant just give you a tune for your engine that will work. Every one is a little different, but I think we can point you in the right direction.
Aloicious, good to know you guys can do this without grenading your trans. I just dont want to go around saying its safe to do on the V8s as Ive seens TrailBlazer SSs with the LS2 go through transmissions (4L70E). Too much engine and weight for the 4L70E.
