has anyone ran into this problem?
anybody???
I think you have A0014 set up around the wrong way,
mine is 0.911 @ -40 through to 1.2 @ 140
you probably right... but i thought that hot air is thinner which would require less fuel???, colder air is more dense which would require more fuel??? kind of lost on that thought...
Yes your theory is right,
but this table seems to work the oposite way around as, you will have seen when you made changes and it got worse.
ok that is how i will adjust it then just needed to see if that was normal thank you!
