When you connect to USB port the V2's LCD should light up and show the splash screen and goto the opening menu (just like when you plug it into the car's OBD-II port).
If it's broken, contact Ira.
yes 3 computers that all used to work. and no pass through does not work either the computer just wont connect said something about cable not being plugged in in efilive scan, i'v also tryed a few usb cables. it seems like its just not able to connect for some reason. but functions perfectly on the car only.
