I thought more simply it may have just been a deceased Polish person. :confused:
Hi Paul,
Im having troubles with connecting to the vehicle with the logger, takes about 3-4 mins, once connected the logger pauses and drops out, this occured ever since the bootblock/firmware update V2.07.01, i have an old FS with the early firmware/bootblock and it works fine. Any suggestions?
After the scan tool software has connected, select the menu option File->Generate error report. Save the report and email it to me at paul@efilive.com.
One thing to try is for FlashScan devices with firmware V2.05.xx or later, in the Scan Tool property window, change the settings to those shown in the image. Make sure you select the V2.5 (HAPI) option and uncheck the "Scan all cables" checkbox.
For FlashSCan devices with V2.04.xx or earlier firmware select the V2 (USB) option.
Doesn't connect to any LS1 holden cars, I tried on three different cars. But work on the rest okay.
Here is the bug I got from the scanner, might help u.
Attachment 9299
I trust you have set the cable selection up as per the screenshot in Blacky's post #13?
Mine wasn't set to V2.5 HAPI so im hoping it will work next car i see.
What is the outlook on BBx Full Flash ??
Problem still exists, selecting HAPI and unchecking "Scan all cables" have not resolved the issue.
Please help, I am loosing a lot of customers.
