Happy Jim -
Should not have to go through that for an update!!
JR
Happy Jim -
JR
Mr. Prick -
I do have an options file in my Config and maybe self test #4, 5, 6 failed, before I don't remember - I doubt it though. I would NOT be a happy camper if I have to delete and reinstall all this software because of this update!!!
JR
Error $0483
Try this:
open EFILive Explorer and copy the new .pmm files and options.txt
to the V2.
You can possibly have a bad install of the software.
Mr. Prick -
I did that twice already!
JR
Well I uninstalled V7.5 & V8 and reinstalled both with the SAME RESULT FAIL 4, 5 & 6. BIG WASTE OF TIME! Unless 4, 5, and 6 are supposed to fail something is wrong!
JR
i updated the firmware to 2.06.09 tonight and had to format the filesystem and set the time/date as it wouldnt connect back up to efilive explorer.
DONT USE 2.06.09! Check for Updates inside your V8 folder in the start menu then flash 2.06.10 in.
And you have to reformat everything when you upgrade past 2.06.07 IIRC, lots of changes occurred that the end user doesnt see.
2.06.09 is the latest file showing up in my directory and i've ran the updates aswell.
apparently not. ran the updates 10 downloaded.
Ok, has everyone updated to bb 2.06.02 and fw 2.06.10 (obtained from V8.1 build 55)...?
When you flashed those did you:
- flash the FS files (and not the AC files)...?
- checkmark Bootblock for bb, and unchecked it for fw...?
After flashing did you:
- format the Config space (using EE)...?
- format the Data spaces (internal and SD, using V2)...?
- copy the relevant *.pmm files and the Options.txt file to the Config space (using EE)...?
