Yes, the Edelbrock was letting way to much airflow through!! I cleaned the rest up with using the MAFFEQ as you suggested. Thanks joecar!!
:cheers: joel
What shift point are you using on that LS6 4L60e?? i have the same combo, but im unsure what shift point to use
Brake cleaner and looking at the o2 millivolts is the best way to find air leaks.
8 Year old thread Bump?
