Ross in another thread said they are finishing up the last details for PCM speed, and then it should be out.
Paul is going to post it up now, but, this will be a semi final release, some PCM's won't have the final cal files done, they will be finished off this week. But, based on the Emails we get, 95% of you will be happy.
Oh God....
Will I be in the 95 percentile! The tension MOUNTS! Time to mix up a metamucil martini to calm my nerves!
Elmer
What timezone are we going by "now" in? :D
I got smart and set my CP so I know what the hell time it is down there.
I just got tired of trying to calculate whether they were sleeping on whatever.
It's 4:22 PM on Tuesday the 27th here.
Elmer
this is a read only release right or is it both with what calibration files you have done the 95 % you talked about
Just sent in my E38 2007 Sierra Denali 6.2L file. I am really looking forward to tuning this truck.
Any idea when will the 6 speed auto tuning will be available?
not sure if it ok to post this here but i cant seem to find where to put it.trying to upgrade the usb drivers so i dont have the hp tuner conflict wanting to read some e38 ecms for you guys. i seen a post saying that needs to be done to keep the hp from having a conflick with efilive drivers. i have printed the instructions off on that and cant get past the correction to step 13 after 6 hours of trying i give. i did it step by step when i get to the no 13 copy (dont move )the ftd2xx.dll from \windows\system32\ftd2xx.dll to \program files\efilive \v7\ftd2xx.dll it doesnt show up under windows\system32\ftd2xx.dll maybe i dont understand it right. if i go though with the install skiping that part says v2 is in working condition when done. seems like it might work guessing there could be problems though if i try not want to toast some ones e38 if i try has me lost. any ideas thanks rich
looks like it doesnt work says my software needs up dated to the hardware sounds like drivers arent installed right
I didn't think Hp & EFIlive could work on the same laptop
