Using EFILive or Tunercat or using Moates EmUtility?
What did it do? I'll have to drag mine out and try it. I have done numerous times with Tunercat, but new to RR stream with EFILive.
It was a while ago but if memory serves me correct EFILive program was not compatable with this PCM, I think!!!
I will try again tonight and see what it dose.
The RR has no clue what PCM it is on, it is more or less a flash memory emulator (not really, but essentially is). I don't know what hooks are in EFIL to allow what programs to go into the RR. Tunercat and EmUtility, don't care and will flash in whatever fits (1MB).
Oh I assure you it is, there are a lot of guys running RRs on 512kb/1MB LS1B PCMs.
I thought I remembered hearing there is an extra key you need to press before clicking the full flash button in the RR control panel. Try opening the RR control panel, then holding down the shift or ctrl key before you click the full flash icon. I dont have a RR, so Im speculating here, if it doesnt work then have to ask someone else who knows.
Yup, there is, forgot, read the RR Tutorial, it is there. Basically you have to bypass an error, like hitting the CTRL key or something when you flash it.
I have managed to load a 512kb program into a 1024kb RR by holding Ctrl & Shift down when asking it to load, all is well now
Cool!
There are no 1mb RRs anymore...
Craig sent me a message that there were many errors with the 1mb pcm for some reason and that it was a hit and miss..
It would be a dream come true if we could get more than 10f/s out of the ls1 pcm when scanning.
