here's a recent tune. its not perfect but you can take a look at it. it OLMAF, 5.7L L31, T56...
These intakes seem like a pretty modest improvement over the factory poppet style but Damn! these things are heavy!! Anyways, I am running an EDGE racing converter with a 2800 stall but i think i have found my problem. I have been very leanient on the amount of timing in the low end due to knock but i have bumped the curve a bit more on the low rpms so all 32 degrees of advance was in by 3000 rpm. Seems like the truck pulls way hard now all the way up to 6000. Im pretty happy with the engine but i wont know the ETs till friday evening. Im hoping to be in the mid to low 12s. With the 150 progressive shot i plan on using in the future once the timing and fueling is established, I really hope to break in the 10s!! So far i am really enjoying EFI tuning compared to carbs. Anyone can twist a screw but most cant understand how much fuel and spark to place across a full 3D map.
EFILive ROCKS!!
I'm using 27lb Bosch injectors in mine and seems through all my tuning that i have the LTFT and STFT just about perfect. I;m using your low RPM spark curve below 3000 RPM and seems like the engine pulls awesome now. Thanks for letting me see your basic tune setup. Seems like a cam of this size in my engine likes a bit more timing than the factory tune to wake the engine up.
Im using a FJO Wideband to monitor all my AFRs. Im not sure how much i have changed my previous tune but if you can find my tune i posted on this site, I am having a problem with PE. Im at work right now and dont have the tune with me; the problem is that i have it commanded for 12.2 at WOT but i am only getting the max of 12.9 according to my wideband. I have not had a chance to log STFT at WOT to see if they are maxed out to determine if the upper portion of the VE table needs to be lowered for more fuel. What do you think?
thanks Aloicious
this will help me get my timing dial'd in right
i have done the auto ve with me lm-1 but had knock at high map like (92)
