Quote:
so if someone with a SBC, like me, wanted to do this, I could pull out my 24x reluctor that I've already installed, and put in your new 58x reluctor, and swap to an LS2 ECM to make use of the internal TAC module, then all that would be needed is the pedal assembly, and correct TB
You also need to use a 4x cam signal. I don't have a pic of our production pieces, but here is the prototype that was used for production.
Quote:
this would make use of the PCM controlled cruize control and other stuff, right? though I'm guessing I'd have to wire some of the cruise control wiring from the brake pedal switch to the PCM or something? Hmmm.....maybe I could have an 1996 E38 controlled truck....heh :rockon
edit- nix that, I just read that the 58x conversion with gen IV controllers don't support cruise control on the due to the CAN/BCM setup. sounds like keeping the 24x and looking for the correct TAC/etc is still the way to go.
You got it.
