Save this folder (or Win7 equivalent) to a USB memory fob: My Documents\EFILive\V7.5
If I was using a cos is there anything I need to copy to the new computer I just bought. I just downloaded the software.
Assuming you had the latest (or at least a recent release) on your "other" computer you could probably just copy the 'My Documents\EFILive' folder to the new system. This is of course assuming you save you tune and log files under that structure.
OK IM planning on doing that. How about the COS Calibrations - do i need to copy any of those over to the new computer.
You should take your calibrations that are based on the COS OS. But, the actual COS calz and files you used to covert to COS in the first place are included in the default software install. :)
