Change these to No to disable max line pressure.
If you disable the processing enablers, then the MAF DTC's will not be triggered...
If the PCM does not see a MAF DTC, then it won't go to SD (VE only) mode...
i.e. when the PCM sees a MAF DTC, it fails over to SD mode.
i.e. the presence of P0101, P0102, P0103 signifies that the PCM is now running is SD mode.
Quote:
Thanks "Joecar" & "5.7ute."
:cheers:
What is GM's reasoning for the MAF tied to the transmission pressures?
I don't see the need. Isn't TPS fine for it? Or does it really use Calc Load and that is thrown off without a MAF so it goes max hard to make up for the lost value?
If airmass calculation is low, then commanded transmission pressure will be low, this allows clutches/bands to slip during high torque.
airmass -> calculated torque -> commanded line pressure
Look for P0101,2,3 in tables E010x.
Some vehicles have those set to No
I set mine to NO when I killed off the MAF. It was bad and I figured it was a good time to tune without it and see.
Only problem I have is low airflow at low speed it stalls sometimes. I can't figure out what is up, even when driving, it almost seems like DFCO is set to aggressively. But it is set stock.
