Well you can feel the brake engage, but the band doesnt hold tight enough. Modifying/testing again tomorrow.
HOLY SHEEET! This brake locks in/releases faster than any other Automatic 4L80 brake on the market!!!!! Havent compared the manual brakes, but it does work with manual setup too.
http://www.youtube.com/watch?v=MZBZOamnh1E
Keep in mind we forgot to command max line pressure (it setup slower because of this) and we were commanding the solenoids thru the HPTuners (boooooo! I am saving up for EFILive as we speak :rockon:) scanner....on a direct switch and max line pressure it will setup and release even faster.....
Oh and the car is slow to react since its just blowing the street tires off :cheers:
Thanks for the vid...:cheers:
