maybe it's not limited in the newer os then?
all the e38 tunes i have looked at including the 09 model holdens with 1 maf table are limited to 7.9999
Apparently starting with '09 LS3 Corvette's the E38 (#12625455) ecm had 16 g/s IFR's. The 2010 Camaro uses a different ecm (#12633238), but it has the same limits as the Corvette ecm @ 16 g/s IFR. So it appears I should be able to use the calculated flow rate that Joecar and I discussed originally and would not have to scale unless I later decide to go with injectors greater than 100 lb/hr.
Lucky you. All us other guys get to run with shit g/sec values and a kludged tune :(
