Thanks Paul . As always, you are very helpful! :master: :thankyou2:Quote:
Originally Posted by Blacky
EDIT:
Just pulled down on the panel below the driver's steering column. My car is a VX2. The 12V red wire should actually be plugged into the top left slot of the (spare) 12V switched source on the VX, whereas Blacky's VT clearly shows the red wire connected to a spare slot in the top right.
Further, I measured the voltage at that point and obtained a reading of 11.96V from ground (where blue wire is screwed down). The voltage signal from the phone harness (along the centre console, see pic below) was actually stronger where I saw exactly 12V. As a comparison, the cigarette plug gave me 11.9V between positive and negative.
http://img.photobucket.com/albums/v7...oneharness.jpg
Just food for thought... spoilt for choices now.
Btw, I'm having some connectivity issues wrt my WO2 atm - I'm using the cig lighter... the EXT.AD2 reading is showing only 2.35V instead of an expected 5.0V.
