I was asking if you copied all your engine tables, and then I thought you would have... :)Quote:
Originally Posted by 1SlowHoe
I'll look at your files over the weekend...
Thanks.
I copied everything except tran diagnostics and calibration. One at a time.
Would the VIN being wrong have anything to do with it?
One tune says OS ID: BD and the other says OS ID: AM
One tune says BCC: DLAC and the other says BCC: DMNP
Is that an issue?
I'm pretty sure the problem is related to the TPS sensor.
I have to turn in my rental car Monday. I you find anything please let me know as soon as you can.
Thanks again:cheers:
BTW: you still have to copy all your old trans tables into the new trans segment.
I dont understand that. How Do I do that?
Same as I copied the engine tables?
I figured stock 80E settings would work fine until I can tweak them.
Do I have to use the "Copy with lables" and paste with labels"?
The trans segment contains the tables you see and some other "stuff" you don't see; so you still copy the tables you see into the new segment (table-by-table individually).
Ok, I will work on that tonight. You think that could have anything to do with my tps/no power problem?
What does "with labels" mean?
Hmm. I am looking at the tunes. Why would I want to copy trans shift pressures, shift at vss, and shift at rpms etc...from the 65E tune to the 80E tune? All those tables would be incorrect for the 80E trans.:nixweiss:
Or are you talking about copying the diagnostics portion?
"with labels" means that the column/row label values get copied also, and when you paste the columns/rows are lined up to match the table being pasted into (so the pasted cells go to the correct locations).Quote:
Oh...Quote:
Arn't you copying from your old 80E tune file (the one that cannot migrate to any COS) to
your new 80E tune file (the one that will migrate to a COS)...?
lol... I missed a few sandwiches... :D
:muahaha: Thats why we arent on the same page. No worries.
I swapped from a 65E to a 80E trans. There is no truck that runs my OS that has a 80E trans in it. I had to swap OS' to one with a 80E built into it. I copied all my non-trans tables into the new OS and flashed it into my PCM. Now I get no TPS response. If I reflash my old tune for the 65E back into the PCM the TPS works fine but of course the trans doesnt respond correctly. I'm missing a table or a setting somewhere in the tune.
