Originally Posted by
BLK02WS6
Here is a writeup I found on the Virtual Flex Fuel Sensor - this was for the 2006 Impala, but the theory would be the same for any flex fuel vehicle that doesn't have a sensor...
"In the past, GM had some small trucks and SUVs that could operate on different mixtures of ethanol-based fuels. These vehicles used a fuel sensor in the fuel line that signalled the computer how much ethanol was present in the fuel; the computer would add or subtract the amount of additional fuel required. Now, the Impala flex fuel system can perform this analysis without using any additional sensors. GM has developed a Virtual Flex Fuel Sensor (V-FFS) software program that calculates the ethanol content in the fuel, instead of using a sensor to measure it. When the fuel level in the tank increases as the vehicle is refueled, the computer recalculates the percentage of ethanol in the fuel and automatically changes the air/fuel ratio. To do this, the computer temporarily stops the operation of other emission systems and monitors the oxygen sensors to determine ethanol content. The test is done several times until calculations remain stable. This can take several minutes when the engine is idling, but much less time at higher fuel flow rates."
and another I found:
"For 2006 and 2007 models, E85 compatible vehicles marketed in North America no longer use an alcohol sensor to determine and adjust for the alcohol content of the fuel in the tank. Instead, the vehicle "learns" (calculates) the alcohol content of the fuel, (and subsequent mixture in the fuel tank), through a series of measured adjustments.
Adjustments
After the re-fueling event, the system registers the amount of fuel that was taken on-board, relative to the amount that was in the tank. Reading fuel trim and O2 sensor activity, the system determines the ethanol content of the fuel that was added. Based on that determination, it adjusts itself to the expected alcohol mix in the fuel tank and lets the fuel trim and O2 sensor activity fine tune the adjustments. The system must remain in closed loop in order for this adjustment to occur. Numerous short trips after switching from gasoline to E85, or vice versa, can result in driveability symptoms due to the inability of the system to adjust for fuel composition (by not attaining the parameters necessary to reach closed loop operation). "
