We have since moved on, see here -
http://www.efilive.com/scan_6.html
Cheers.
Cheers.
Ok, I see...Quote:
Originally Posted by GMPX
In the integrated wide band O2 images:
"AFR :1" is the PCM's commanded Air Fuel Ratio.
"WO2 AFR" is the wide band O2 sensor Air Fuel Ratio.
"O2 SIM V" is the wide band O2 sensor's simulation of the narrow band O2 sensor.
Can you elaborate more on it? Or is that just saying that EFI Live now comes with the PID's already pre-configured, but I will still have to hook the wideband up as described above? Thanks....
do you have to have the complete LM-1 to do this or can you just use the sensor? I've got a wideband sensor the wires are RED YELLOW GREY BLACK WHITE.
It's the BOSCH sensor that comes with the LM-1
Sorry I just saw this. You have to have the complete LM-1 for this to work.
Thanks to JNorris and Blacky for the help on this. I have a Zeitronix Wideband and finally was able to incorporate it into EFI Live. I have a 02' and the colors for the A/C harness were a little different. Red/Black, Gray, and Purple were the colors for my car. I took the output from the Wideband (white) to the Red/Black on the harness. Next, I took the Brown wire (sensor ground from the wideband) and taped that into the purple wire on the A/C harness. This was the easy part.
Onto the PID. This took several attempts to get correct. Here is the current Custom PID that I am using. I have compared this to the actual Dataloger on the wideband and it is spot on. I'm not saying this is the right way, but it works. :lol:
Below are the formulas in my CALC_PIDS.TXT file.
# Calculated
#Units Low High Fmt Expression
*CLC-00-1000
V 10.0 20.0 .3 (0.627*((RAW({GM.ACP})/51)*(RAW({GM.ACP})/51))+(0.457*(RAW({GM.ACP})/51))+9.7758)-0.425
*PRN - Parameter Reference Numbers
# Calculated
#Code PRN SLOT Units System Description
CALC.WBO2 F600 CLC-00-1000 V Fuel "Wide Band O2 Sensor"
I have a dynojet wideband commander and I used your cal pid. Everything works great but it read 28.something when the afr is 14.7. Can anyone explain to me how to fix this in laymans terms.
THanks a ton,
Frank
Do you have any specifications from Dynojet about the relationship between the output voltage and the AFR value?Quote:
Originally Posted by LS1Nova
For example, some wide band O2 manufacturers state something like this:
0V = 10AFR
2.35V = 14.7AFR
5V = 20AFR
Does your dynoject have any similar specifications?
I called tech support, and they said
0v = 10-1
2.94v = 14.7-1
5v = 18-1
Frank
That would make your wide band O2 equation:
AFR = V*1.6+10
so in this http://www.efilive.com/forum/viewtopic.php?t=1145 example, replacewithCode:# ==============================================================================
# Add slot definitions here
# See sae_generic.txt for more information on "SLOT" formats
*CLC-00-001
AFR 10.0 20.0 .1 "{EXT.AD1}*2+9"
RegardsCode:# ==============================================================================
*CLC-00-001
AFR 10.0 18.0 .1 "{EXT.AD1}*1.6+10"
Paul, I'm using the same thing as jnorris in the first post. Basically I need to use a different formula, but I am braindead and can't figure out how to do it.
I'm using my analog output voltage to go into my a/c pressure sensor with V6.
Your right my afr=v*1.6+10
Frank
