Paste-with-labels automatically aligns the table you're pasting so that the axis row/columns align to the correct values...
You can ignore that parameter.
After you're done copying/pasting, save the file and flash it in, then read it out, this will now be your starting tune...
and make sure your engine/trans run correctly.
next problem how do I adjust my map to give the correct reading?
and where?
with the key on but truck off the two bar reads 97.
another stock car same location stock 1 bar reads 99.
Where do I make the change and how?
See C6301 MAP scaler.
Yes correct, KOEO (key on, engine off) MAP has to read the same as barometric pressure, see the description of C6301.
Now i'm creating my Create AutoVE MAP
EFILive Scan Tool Software but when i copy my table with lables off of table b0101 and Press the Paste Labels button on the scan window in the map properties it say list index out of bounds (-1) the menu heading on that message is digital tools for on board vehicle electronics? will this be okay?
then it paste but it leaves row 1 blank last row blank. 1 column blank and last column blank?
Do you click the Paste Labels button...?
No, something is going wrong, the heading should not say that.
What is the V7 build version...?
and yes i clicked on paste button
Post some screenshots showing what you're doing and what is going wrong...
Ok, it looks like it pasted the right labels for each axis...
