i just sent blacky a pm about this issue. the ad/external inputs have nothing to do with the problem imo. as i turned all of them off, deselected the pids from my list and still couldnt get it to work.
The workaround for now is simple and I have no idea why it works, but this is what i found out last week.
instead of opening the scanner software directly, open up a previous log file done by the v2 or v1 unit itself (by bbx), connect to the ecu, remove any pids or add ones you want if your not happy and start logging.
Everything will work like it normally would.
