Version: 8.2.1 Build 203
firmware is 2.07.35
yes but with analog, since i never got my serial to work.
Which analog wideband...?
in that calc_pids.txt you will have to modify (using Notepad) CLC-00-110 to read as follows (using LC-1 as example):
Code:*CLC-00-110
factor 0.5 1.5 .4 "{GM.EQIVRATIO}*{CALC.AFR_LC11}/14.7"
Those screens indicate that dditionally you need to select the mentioned pids in the More Info boxes (CALC.PE in screen 1, CALC.DAT in screen 3).
Temporarily, disconnect the wideband's analog cable from V2 and see if the error in screen 2 goes away.
Also, mention of CALC.PE tells me you have the older calc_pids.txt file (since the newer file changed this to CALC.CL).
Which wideband do you have...?
Were you not able to get it connecting with serial comms...?
Please see this thread.
http://forum.efilive.com/showthread....light=loopback
Because you are using the analog/external PIDs and deselecting them is not an option, you will need to create a loopback link for AD1 to force the A/D counts for AD1 to be zero.
Then you'll need to hook up the wideband to AD2, and use the AD2 PIDs for wideband logging.
It is fixed in the next update. That update was due out earlier this week but some last minute problems appeared in final testing and they are still being fixed.
It may be another week before it is ready.
Related threads:
Scan-Tool-Error
Logging-issues-with-NGK-AFX&p=184367#post184367
Hi rumblebox,
I took the liberty of renaming this thread.
