Also is there a delay for SOL to enable?
The implications of this are as follows:
CL with LTFT disabled:
- this is still CL mode,
- LTFT trimming has been disabled,
- STFT trimming has been disabled (either explicitly via B4206, or implicitly via LTFT trimming being disabled, depending on COS),
- OLFA tables B3647/B3649 are not active (because we're in CL mode),
- when you enter PE mode, the PE table B3618 is the only active fuel table;
SOL:
- this is OL mode,
- STFT trimming is enabled on stoich cells of B3647/B3649,
- OLFA tables B3647/B3649 are active (because we're in OL mode),
- when you enter PE mode, the active tables are B3618 and B3647/B3649, so commanded fuel is the richest of the current cell in those tables;
Note: for those COS's that have B4206, SOL may still function even when B4206 is disabled, you have to check this (by viewing what the wideband shows).
I R CONFUZED. If the o2 is correcting fuel, then it's the same thing isn't it? LTFT disabled and zerod, there will be no overall fuel correction, other than the o2s pulling the a/f mixture to stoich. Correct? Isn't that exactly what STFT enabled, LTFT disabled is doing too?
Is it just because that's the way the COS is? It would seem that disabling the LTFT on a non-COS would yield the same results. Am I correct? Is the wording what changes? I think that's where the confusion is, maybe lol
