Awesome PID selection! I see some long desired parameters!
Yes i just tested it and "Validate PIDs" is MANDATORY!!!
Other than that it's perfect
Sent from my iPhone using Tapatalk 2
Right! Should rarely need a pid not included in EDA!
Those are handy but my test trucks have them and not feasible in customer rigs most if the time would definitely be a plus for competition set ups
Validating PIDs did the trick. If I switch tunes 2 or 3 times when data logging the V2 will stop working. I have to unplug it for the pc and then it will start working again. Is this normal?
One issue I have had I named the tunes in v8 and programmed v2 names were correct then somewhere in the haste of trying to get EDA to work in v7 the names changed. All names in incremented up one spot, 1 moved to 2, and 2 to 3 and so on. The name for five is gone and tune 1 is named just that "tune #1" on the v2. The names are still correct in v8. I have erased and renamed in v8 and reprogrammed but they remain the same. Small issue and names aren't real critical but an issue none the less.
