that's got to be the cleanest install i've seen! Great work!Quote:
Where do you install the bung in the exhaust stream if its true dual up to the front of the muffler? That would put the bung between the cats and muffler. If the bung can be placed on either side, it seems this would make an inaccurate reading since you're only getting exhaust output from one side.
Mine is a true dual all the way back and I only installed one on the passenger collector. You could install a wideband in each collector and log them alternately and adjust your VE table using an average of the two but I have found that to be unneccessary as long as both sides are close. After I tuned using the Auto Tune procedure and then recalibrating my MAF, my trims are looking very good - and very consistent - on both sides. I do have a matched set of 30 lb. SVO injectors and I've logged trims quite a bit to ensure this.
Sweet write-up! :)Quote:
