And this...
# File details
# This section defines various details about the file format.
*FILE
#Parameter Value Description
VERSION 7.1.1 File version
DECSEP . Decimal separator used in this file
# Units
# See sae_generic.txt for more information on the *UNITS section
*UNITS
#Code System Abbr Description
None None "" "No units"
# Add slot definitions here
# See sae_generic.txt for more information on "SLOT" formats
#Units Low High Fmt Expression
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
Stubbling around I found this ...is that what I need? My level of ignorance here shameful . thanks for assisting.
-- WO2A.AFR_WBC1
return pid("AD1")*1.6+9
I tried to change those properties in v8 and could not get them to show up once I selected that pid when I checked the pid properties. Still looking for help please.
Copy the attached calc_pids.txt file to this folder: My Documents\EFILive\V7.5\User Configuration
and then start the scantool and select the pids CALC.WIDEBAND and CALC.WO2BEN.
Edit: file deleted because it was corrupted (CRLF got munged).
It says invalid attachment when I try to open or copy. Could you email to [email protected] ? THANKS for helping!
tried again, got it loaded, will report back. THANKS
open scan tool and got this error...
Error code: ERR_CONFIG/92
C:\Users\st0114\Documents\EFILive\V7.5\User Configuration\calc_pids.txt(81): Slot CLC-00-100 with units “LAM not found. .
Quote:
Originally Posted by
joecar
oh, hold on a sec...
Joe, is it something I could have done wrong. I copied the entire text in place of the other text in the Calc_pids under the My Documents\EFILive\V7.5\User Configuration. Looked correct because the first part of what you sent was exact to the first part of what was there so I replaced the entire text with what you sent. I am just being overly cautious telling you this. Don't want you to be running down my mistake. THANKS for your help as always!
PS I cannot open tune or scan with this error code.
2 Attachment(s)
The calc_pids.txt file that Joe posted has been somehow corrupted. I've fixed it and attached it to this post as a zip file.
After unzipping the calc_pids.zip file so that the calc_pids.txt file ends up in the \My Documents\EFILive\V7.5\USer Configuration folder, re-start the V7.5 Scan Tool software and make the following PID selections:
Attachment 17295
