I reworked your stock TCM tune ... set the TCC slip RPM to zero for all gears (like a Corvette) given that you don't have AFM. I also increased the TCC pressure ramp in rate, and the TCC pressure (this is the only parameter changed that is not available in EFILive).
Hopefully this helps ...
