I just swapped data over plan on premium fuel unless you would say 85 would be better I'll adjust those and see what we come up with then thank you for the time to look at it
I moved b3601 from 10 to 13 or should I go to 14 to be better
b3606-7what should I set to so there isn't a danger zone b2618 isn't coming up in search and on b5913-14 would I use the same table as high I do apologize for the questions a little new at the gas side of things
B3601: set to stoich AFR of your fuel (9.7 for E85, 14.2 for E10, 14.6 for E00)
B3607: set to EQR 1.13
B3607: set to ERQ 0.95
B2618 is a typo, sorry, it should say B3619.
B5913: use F-car HO table
B5914: use F-car LO table
No worries.
Thank you Joe should have it all back together this week sometime just gotta order my injectors thinking 50 or 60 lbs then adjust for those
Attachment 22762Attachment 22762Attachment 22762
here is with the f car tables and the other adjustments
Did you set B3616 and B3618...?
No sir I haven't as of yet i took the efi university online classes to get a better understanding which opened up alot but those I'm not sure of
