New first of Feb: Bosch 0261230289
Looking at frame 9900:
rpm 2501 spark 38
map 3.6 afr 13.878 wo 12.46
app 0%
mafsd 24g/s vss 0mph (how does that happen)
So is this crazy or what. This is similar in a few places like you said. As a newbie I have not idea where to start.
Of course I haven't got a handle on creating maps yet. One reason I do not know what to do with the data!
I appreciate you observations.
Yeah something weird is happening with your vehicle speed, it drops to 0 then jumps back up. Can you check your connections at the vehicle speed sensor and the engine computer?
The MAP sensor and the parameters for it in your tune are right, just wanted to double check.
Definitely need to figure out the speed thing first, if you're getting any bad signals to your ECU, you won't be able to get a solid tune on it.
