I should have been more clear. My understanding is airflow, determined by the MAF sensor, is used to calculate fueling. If the MAF reading at idle is 59 g/sec but the actual number is closer to 40 g/sec it seems like the ECM doesn't have the correct information. And if that's the case it seems like the engine should run poorly or at the very least smoke, which it does not since the computer thinks it is getting more air than it is and as a result provides more fuel.
