Thank you for the incite. I have installed the 2 bar sensor and the truck starts and dies within a second or two after which it cranks and stumbles but doesn't start up. Is there an adjutment that needs to be made under the Engine Diagnostics > Map section?
Ok.
Which 2 bar did you buy?
Got to adjust the settings for it and some more settings as well.
I requested the delco part # you supplied but the parts guy ordered me a Standard AS314 after it came in he said it was a direct replacement.
Ok making sure.
Ill update those numbers and send you a revised startup tune
Thank you for checking up and making sure I had the correct part. Sounds good I appreciate your help.
I forgot to update those numbers.... I gotta go get the other laptop that has the newer software version..
Cool thanks I'm in Deadwood for new years which is 300 miles away from the Yukon. It will be Monday before im back. Happy New Year.
I am back from vacation and I am hoping to get this Yukon up and running is there anything you need from me on this end data or parameters wise?
1 Attachment(s)
Data Log
Here is a speed density data log. I am trying to understand what I am looking at in the maps vs what I will change in my VE table, is it correct to have dyncylair / LTST as the table I am looking to lean out? Thanks in advance for any pointers or tips.
Attachment 24978
