I went outside and checked today again here is the break down
FJO WB software = 20:1 AFR
Analog output with the cable unhooked was 5.02
Analog output with the Flashscan cable hooked up was 4.98
EFILive Scanner read 4.78 v in the log and an AFR of 19.55 using the formula
What I did was left the voltages alone since they varied to much and concentrated on the afrs. 20/19.55=1.0230179028132992327365728900256. I then took this and used it in my calc pid as a calibration factor. Now the FJO software reads 20 and the scanner reads 20.
My ve table was then lowered for all cells by -2.30179028132992327365728900256%
