Quote:
Originally Posted by Delco
I would think we need to standardise the installation for a newby ( and us dumb ass oldy's) so it asks upo installation if you want metric and imperial , also some added setup options upon installation - ie do you want to ue your defualt pids dash etc .
The current installer checks for the windows localization setting and if it is "US - English" then all settings default to imperial. Otherwise all settings default to metric.
The problem really occurs when you change a chart or gauge to metric while leaving the default PID settings (on the [Data F8]) tab page.
I seem to have lost the option to automatically validated pids on startup - what setting have I forgotten ?
Thanks for that Paul , I will delete that file because lately it is coming up with lots of invalid pids unless I validate them - my version has been played with that many times I should delete it and start fro a fresh installation :oops:
PIDs will only be auto validated when a VIN is encountered that has not been encountered before. Only the first 9 and 11th chars/digits are used in the comparison. (the 10th is a checkdigit and 12-17 are a sequence number which are all ignored).
You can manually re-validate PIDs with Shift+F2.
or delete all the *.vpl files - that will cause PID validation to occur for each new VIN type, because no matching *.vpl (validated pid list) files will be found.
