Seems all the COS tables are different.
Comparison summary: 04:02:50 pm, Monday Sep 24, 2007
Calibration comparison between Current tune as of 180707.tun and Current tune as of 180707_trany swap.tun.
*Values that differ by more than 0.100000% are considered different.
A0000 "Forced Octane Scaler" N/A "CAL: Disable <-> ALT: 255"
A0001 "Forced Octane Scaler Percentage" 1499.9756 "CAL: 100 <-> ALT: 1600"
A0002 "Octane Scaler Limiter" 1499.9756 "CAL: 100 <-> ALT: 1600"
A0009 "Boost VE Table" 83.4945 "Different from cell: 0,0 to cell: 18,19 inclusive."
A0014 "IAT VE Multiplier" 2999.9509 "Different from row 0 to row 18 inclusive."
A0010 "Boost Timing Table" 6399.9023 "Different from row 0 to row 18 inclusive."
I just did the same thing and got the same results.
Took my COS 02020003 file and did a Trans Calibration and Diagnostic segment swap and all my COS tables and parameters went to flat values.
I would think that if you just copy all of that over from your old file and do a full flash with the new file, you should be good to run. Weird though.
Thanks Max,
Must be something to do with it being a COS.
I'll PM Paul and see what he thinks.
The EFILive custom calibrations are allocated in segment 0. So to transfer custom calibrations you need to copy segment 0.
Even though segment 0 is called the "operating system", copying segment 0 does not copy the operating system, it only copies EFILive custom calibrations.
Sorry Paul...you lost me!
I just copied the trany tables to my tune and as I did my COS tables all changed.
Hey Howard,
I am using COS3 not 5. My tune should flash right into your truck.
G'day Howard,
Are you saying you copied only the trans segment from a 4L80E file to your COS3 file, and the custom cals are now different...?
Joe
2 Attachment(s)
Yes Joe...thats exactly what happened.
Here's the two tunes...before and after.
Thanks Jeff....I didn't realize that.
Howard
It should not do that - I'm looking into it.
Thanks Paul. This is why I like this forum so much...it's also why my JET DST hasn't seen the light of day in a long time! :D
